| Comp Cams Kit https://slantsix.org/forum/viewtopic.php?t=11515 |
| Author: | 73dart_swinger [ Sat Jan 22, 2005 1:28 pm ] |
| Post subject: | Comp Cams Kit |
those of you running comp cams, did you buy the cam alone, cam and lifters or the whole kit? im looking at cams to i was curious what others had done. |
| Author: | slantzilla [ Sat Jan 22, 2005 2:26 pm ] |
I bought cam and lifters because my head already had good springs on it. |
| Author: | zedpapa [ Tue Jan 25, 2005 12:52 pm ] |
| Post subject: | comp cams |
i bought a used comp cams 252s off ebay(!) and i called comp cams and they said i could use it with my original springs and lifters. since my engine had less than 15,000 miles on a fresh and complete rebuild i wasn't worried about getting new lifters or springs. the 253s is slightly above stock though. if you want anything larger i would suggest getting the 340 springs. i have heard that they work real well and are a direct replacement. zedpapa |
| Author: | 73dart_swinger [ Tue Jan 25, 2005 3:34 pm ] |
what about the timing chain they show coming in some of the kits? anyone ever used one of those? |
| Author: | DusterIdiot [ Tue Jan 25, 2005 8:43 pm ] |
| Post subject: | Some of one, some of the other... |
I used the Comp 252, used a matched set of stock springs (went through a can of them to find a uniform set), at the time lifters were getting hard to come by so I ended up having to buy a small block set of mech. lifters (so now I hve extras...) The best timing set I've seen yet is the one Cox Brothers offers, especially if you are degreeing the cam in. -D.Idiot |
