| rebuild kit https://slantsix.org/forum/viewtopic.php?t=11531 |
| Author: | Guest [ Sun Jan 23, 2005 5:54 pm ] |
| Post subject: | rebuild kit |
ok where is the most inexpensive place to order a 60 over rebuild kit for a slant 6. also what do i need to tell them when ordering. I have no idea what year model engine i will be rebuilding it is in pieces on the floor of my shop. any help will be appreciated. thanks norm |
| Author: | Dart270 [ Mon Jan 24, 2005 12:12 pm ] |
PAW should sell a kit inexpensively. If you want a crank with the kit, you will need to tell them if it is 67-down, 68-76, or 77-up (cast). If it's 80-up it'll have hydraulic lifters and you'll have to specify that. Look on the stamping pad on the front right corner of the upper block deck for a date. Lou |
| Author: | NORM [ Mon Jan 24, 2005 1:23 pm ] |
thanks lou i will check it out tonight. time to revive the old duster |
| Author: | 70survivor [ Tue Jan 25, 2005 5:20 pm ] |
I was pleased with master rebuild kit I got from Northern Auto Parts. Just spend the extra money for the Fel-Pro gaskets. |
