What's up with these rear ends?
https://slantsix.org/forum/viewtopic.php?t=11532
Author:  '74 Sport [ Sun Jan 23, 2005 10:57 pm ]
Post subject:  What's up with these rear ends?
Just got back from looking at a couple of '62 model cars. One was a Plymouth Valiant and the other was a Dodge 440. They both had rear ends that look strangely like the 8-3/4", with no bolts on the "dog dish-looking" backside of the differential. What are they and would they be a viable replacement for the 7-1/4" in Aaron's '74 Dart Sport we are working on?
Jerry
Author:  Eric W [ Sun Jan 23, 2005 11:03 pm ]
I want to say those early axles are an odd-ball size, like 8 3/8" or some thing like that. Could be wrong. :shock: :wink: Anybody else?
Author:  Pierre [ Sun Jan 23, 2005 11:06 pm ]
Don't those early axles have funky drums held down by a single nut in the center similar to front drums?
I would keep looking, I'm sure you'll find a suitably priced 8.25 or 8.75" Keep looking around the yards. I'm not sure how far they are away from you but call up www.TexasAcres.com or www.Texastoybox.com
Author:  Dennis Weaver [ Mon Jan 24, 2005 6:23 am ]
Those are 8.75" rears, they got the retaining nut on the axles, keep looking!
D/W
Author:  73dart_swinger [ Mon Jan 24, 2005 10:02 am ]
texas acres had a 8.25 when i called them last a few months ago. they want around 350 for it. good luck finding a rear, ive been looking for one as well. not much luck here sw of ft worth. if u find an extra id be interested.
Author:  '74 Sport [ Mon Jan 24, 2005 10:13 pm ]
Here's a reply from Gary on [url]forabodiesonly.com[/url]:
The 440 has the pre-1965 version of the 8.75, with the tapered
axles.
The 8 1/4 Valiant also would also have tapered axle version. It's not
as easy to service the brakes or swap gears out as the later 8 1/4
versions. Probably not what you want.
There's also a Spicer 9-1/4" option for you to consider. See the
bottom of [url]autohobbydigest.com/a-rearend.html[/url]
That site has some good information concerning other things I have wondered about.
Thanks for your replies fellows. I took the 7-1/4" to a shop today to get freshened up (new pinion and axle seals, check bearings and gears, sandblasting, and priming).
Jerry
Author:  Jeb [ Tue Jan 25, 2005 4:05 pm ]
See if you can locate a posi-unit on e-bay. These make the tiny 7 1/4 able to stand up to even a 318.
Author:  73dart_swinger [ Tue Jan 25, 2005 4:52 pm ]
good luck finding a posi for the 7.25, i think ive only seen one and ive been an ebayer for a while now.
Author:  Charrlie_S [ Thu Jan 27, 2005 3:37 pm ]
Jeb is correct about the posi (oops) sure grip, really making a difference in the strengh of the 7 1/4 rear. I ran a 7 1/4 SG for years, untill I upgraded to a 8 3/4 i 2003. I ran a 3.91 for the 1/4 and a 5.13 for the 1/8 in two different rears. But the 7 1/4 SG is hard to find. Just have to keep looking. My spare SG unit, took me over 2 years to find.
PS: the 7 1/4 rears will be going back into service this year.
