It is currently Fri Nov 20, 2026 8:56 pm
 Post subject: what brake hose
PostPosted: Wed Jan 26, 2005 12:24 pm
i am doing the large bolt pattern disc brake swap using the f body spindles, rotors, calipers and am needing to know which brake hose to get. i have heard that it is the 73-76 hose but am not sure. the article at bigblockdart.com is not clear on what hose to get.
zedpapa
p.s. if anybody has the 73-76 uca w/big balljoint, i'm interested, but be warned, my wallet is extremely thin at the moment. been on a diet since i got married! :)
soon to have 5 gears!!!
PostPosted: Wed Jan 26, 2005 8:39 pm
Which way are you facing the calibers? A stock A-body is on the front and you can use a '75 Dart brake hose. If you have the calibers toward the rear you will need a F-body brake hose and an extension on the steel line to help route the rubber hose.
 Post subject: Condran says
PostPosted: Wed Jan 26, 2005 9:39 pm
The Condran book says use a 73 Valiant (73-76 A body) hose
for the 73 and up slider brakes OR 80 Volare hose if 11 3/4"
rotors are being used.
The 73 Valiant hose is also specified for 76 and up pin type
calipers.
On the setups described the caliper is to be mounted at the
stock location - toward front of the car for 73 and up.
 Post subject: what hose
PostPosted: Thu Jan 27, 2005 4:59 pm
i will be installing the calipers on the rear to make sure i have plenty of room for the sway bar i hope to add soon. i will be using the 11 inch rotors and the sliding calipers.
zedpapa
PostPosted: Fri Jan 28, 2005 9:44 am
My Dart uses Aspen / Volare hoses. I'm running A-body spindles, 11.75" rotors, and rear mounted slider calipers. I was able to attach these hoses directly - I did remove a bracket that was on the hoses, but I didn't need any additionaly hardware.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
