| what brake hose https://slantsix.org/forum/viewtopic.php?t=11548 |
| Author: | zedpapa [ Wed Jan 26, 2005 12:24 pm ] |
| Post subject: | what brake hose |
i am doing the large bolt pattern disc brake swap using the f body spindles, rotors, calipers and am needing to know which brake hose to get. i have heard that it is the 73-76 hose but am not sure. the article at bigblockdart.com is not clear on what hose to get. zedpapa p.s. if anybody has the 73-76 uca w/big balljoint, i'm interested, but be warned, my wallet is extremely thin at the moment. been on a diet since i got married! |
| Author: | kesteb [ Wed Jan 26, 2005 8:39 pm ] |
Which way are you facing the calibers? A stock A-body is on the front and you can use a '75 Dart brake hose. If you have the calibers toward the rear you will need a F-body brake hose and an extension on the steel line to help route the rubber hose. |
| Author: | relic-lover [ Wed Jan 26, 2005 9:39 pm ] |
| Post subject: | Condran says |
The Condran book says use a 73 Valiant (73-76 A body) hose for the 73 and up slider brakes OR 80 Volare hose if 11 3/4" rotors are being used. The 73 Valiant hose is also specified for 76 and up pin type calipers. On the setups described the caliper is to be mounted at the stock location - toward front of the car for 73 and up. |
| Author: | zedpapa [ Thu Jan 27, 2005 4:59 pm ] |
| Post subject: | what hose |
i will be installing the calipers on the rear to make sure i have plenty of room for the sway bar i hope to add soon. i will be using the 11 inch rotors and the sliding calipers. zedpapa |
| Author: | Matt Cramer [ Fri Jan 28, 2005 9:44 am ] |
My Dart uses Aspen / Volare hoses. I'm running A-body spindles, 11.75" rotors, and rear mounted slider calipers. I was able to attach these hoses directly - I did remove a bracket that was on the hoses, but I didn't need any additionaly hardware. |
