It is currently Fri Nov 27, 2026 10:28 am
PostPosted: Sun Jan 30, 2005 5:57 pm
What are the measurments for pre 68 crank hub and the measurements for the later crank so that at a junk yard I can measure to make sure I get the right one. Does clutch size make a differance? thank you. Ranch guy
PostPosted: Sun Jan 30, 2005 7:00 pm
The 68-up hub is 1.815" ID, 67-down is around 1.66". Can't remember ODs. Clutch size does not matter, but the flywheel centering holes will be different for the two crank hub sizes.
