| Crank hub size . What are the measurments for pre 68 https://slantsix.org/forum/viewtopic.php?t=11603 |
| Author: | Ranch Guy [ Sun Jan 30, 2005 5:57 pm ] |
| Post subject: | Crank hub size . What are the measurments for pre 68 |
What are the measurments for pre 68 crank hub and the measurements for the later crank so that at a junk yard I can measure to make sure I get the right one. Does clutch size make a differance? thank you. Ranch guy |
| Author: | Dart270 [ Sun Jan 30, 2005 7:00 pm ] |
The 68-up hub is 1.815" ID, 67-down is around 1.66". Can't remember ODs. Clutch size does not matter, but the flywheel centering holes will be different for the two crank hub sizes. Lou |
