| electric fuel pump https://slantsix.org/forum/viewtopic.php?t=11638 |
| Author: | ShivaDart [ Thu Feb 03, 2005 10:21 pm ] |
| Post subject: | electric fuel pump |
Right now I'm installing an electric fuel pump, but I need some help. For the positive wire of the pump what wire on the car should I use? So far the best I've done is to be able to give the pump power when I have my key turned to accesory two and also have power when the engine is on, the problem is that I want to give the pump power only when the engine is on. Is there a wire I could hook into that would fulfill that requirement? I plan on getting an oil pressure shut off switch real quick(and also probably an inertia shut off switch), but really don't like the idea of driving my car in a situation where if the engine shuts off fuel's still being pumped even for a small amount of time. Plumbing underneath a car is so much fun... hmmm... road dirt and car filth... yummm |
| Author: | Eric W [ Thu Feb 03, 2005 10:30 pm ] |
Field wire from the alternator maybe? Thats where I have power for the electric choke sourced from. |
| Author: | Pierre [ Thu Feb 03, 2005 10:31 pm ] |
Make sure you check out the current requirments of your pump. Chances are your going to need a relay unless its a low pressure small-ish pump. |
| Author: | ShivaDart [ Thu Feb 03, 2005 11:00 pm ] |
It's a small faucet pump that runs about 3 Amps and puts out 1.5-4 PSI. Eventually it will be used to feed a surge tank, but for right now I'm going to use it to feed the Carb. As for the alternator wire, that's actually where I figured first, but then I found it does get power in the accessory two position(suprised me). I may end up having to settle with the alternator wire and finding an oil pressure kill off switch ASAP. |
| Author: | slantzilla [ Fri Feb 04, 2005 12:20 pm ] |
A really cheap oil pressure kill switch is a stock sender for a '78 up Slant. They ran the power for the choke through the OP switch. Make sure they give you a 3 terminal one. I got one at Autozone for about $4. |
| Author: | Guest [ Sat Feb 05, 2005 3:46 pm ] |
Two good reference points you can use are oil pressure, as already noted, and vacuum. A vacuum switch for propane systems will also work on your setup, just unscrew a plug on the intake runner and thread it into that for your signal. The trick is to adjust the switch on the sensitive side, so the pump doesnt shut off when you hit the gas. Also a cheap switch. |
| Author: | ShivaDart [ Sat Feb 05, 2005 4:59 pm ] |
Thanks for your replies, I did finish getting the pump wired in with it on in acc 2 and on position, then after fixing any leaks that showed up I drove my car around town and then thrashed it in a parking lot for quite a while making sure that anything that could break would break with me setup to fix it, luckily nothing broke Anyway, Slantzilla, what sender are you talking about(or, what would I ask for at a parts store), and I'm not sure how I'd wire it in. Guest, how much are the switches you talk about? From what you say, it sounds like the screw in port on the intake would be blocked by this switch, unfortuneately I need this to power some vacuum items already, and eventually will be used for a MAP sensor, would this switch be able to be hooked up to a vaccum port off the carb or something? Sorry for not replying right away, I wanted to get everything running well, now I want to make it safe |
| Author: | Rust collector [ Sat Feb 05, 2005 5:44 pm ] |
I think all aspens used the oil-pressure switch. |
| Author: | steponmebbbboom [ Sat Feb 05, 2005 5:45 pm ] |
Eric, both switches could be had pretty cheaply, though zilla's oil switch might be a little easier to locate. You can always run the vacuum switch off a tee fitting so you don't lose your vacuum accessories. Ive looked in the Carquest catalog at oil pressure switches before, there is a three terminal switch in there for a Kcar with the 2.2 (i think?) that has three spade terminals, one a common, one normally open, one normally closed, I ended up using this switch on a forklift with a perkins diesel to run both the oil light ground path (normally closed) and the truck's hourmeter (normally open). You can just as easily power the fuel pump ground with the normally open circuit. And do try to use the ground path, as doing so will keep the hot wire as short as possible and you have less chance of blowing a fuse. Run the common terminal to a good chassis ground and you can do both functions with the one switch. |
| Author: | slantzilla [ Sat Feb 05, 2005 10:30 pm ] |
The 3 terminal oil pressure switch will have 2 copper contacts and 1 brass. The copper ones are the ones you want to use. Power wire in and the supply wire out to your fuel pump relay. |
| Author: | ShivaDart [ Sun Feb 06, 2005 7:55 pm ] |
Thanks for your replies, I'll check those out |
| Author: | guest [ Tue Feb 15, 2005 11:56 am ] |
If you need alternator current or oil pressure to operate the fuel pump, then what happens if you run out of gas? Just thought I might ask. |
| Author: | steponmebbbboom [ Tue Feb 15, 2005 12:56 pm ] |
Unless your engine is really whipped, you will build enough oil pressure during cranking to throw the switch. Vacuum switches also will operate with the engine run out of fuel, though they will not work if you floor the accelerator. But if the engine is out of fuel, it isn't going to start anyway... |
| Author: | guest [ Tue Feb 15, 2005 1:52 pm ] |
Obviously the vehicle won't start if there's no fuel. The point of my question was to point out how hard it would be to prime the carburetor after putting some fuel in the tank. Of course, you could install a bypass switch that would allow you to power the fuel pump while the engine is not running. |
