It is currently Sat Nov 28, 2026 2:15 am
PostPosted: Fri Feb 04, 2005 9:25 am
Check out what I found on the redline webber site,
Complete throttle body injection kits, I have no Idea what the cost is but looks like a good setup.
I wonder how this would work on slant6.
Heres a link to the fuel injection page.
http://www.redlineweber.com/html/thrott ... deshow.htm
PostPosted: Fri Feb 04, 2005 10:31 am
That looks very cool. For someone with the money, knowledge and time it would take, this is probably the best setup currently available.
The biggest drawback to a system like this is not the money. The time it would take to dial this in would be huge. The software would not have a mask(primary setup code) for a slant. It definitely would not have one for a slant in your car with your mods...or anyone elses for that matter. This means you would have to start from scratch on programming. For the first week a stock 225 with a Carter BBS would run faster and smoother.
I have 2 FI projects on the go. In both cases I was able to start with a fairly close mask and go from their. Remarkably the more radical of the 2 projects has been fairly easy. It runs well, makes huge torque and gives good fuel economy. The other project has given me fits since last April. Recently I made a huge leap forward by discovering a large ground strap on the ECU made the sensors more sensitive. The car runs much better and doesn t throw codes all the time.
My point is: buying a kit like this is only a tiny start in a huge process. I will be doing the slant in the Valaint, but only because I can use a 747 ECU with readily available masks to get me started. If the software in the REDLINE kit doesnt include an applicable mask I would pass till it does.
Dont get me wrong,,,I would love this on a Lynx manifold (or similar) but I want someone who really knows there stuff to live in my shop for 4 months and dial it in.
PostPosted: Fri Feb 04, 2005 11:46 am
Sounds like is something I should probably avoid !
I dont really know much about fuel injection, but I would like to convert to it someday.
For now, i'm getting ready to do a supersix swap. Hopefully it will run better than my holly 1bbl.
PostPosted: Fri Feb 04, 2005 12:16 pm
A Super 6 swap is a really good idea. It will run better and offer up more HP than your Holley. You may also experience slightly better gas mileage. It is easy to swap and requires a minimum of tuning to get running nicely. I have a Super 6 on my car presently. I found an early 60s 318 Carter BBD is an excellent carb for this application. The whole combination benefits from a 2 1/4" exhaust and a little advance curve tweaking.
 Post subject: Redline Fuel Injection
PostPosted: Mon Feb 07, 2005 2:59 pm
Clifford sells the Weber Redline setup for the slant 6 for about $2K. FWIW, I think its way overpriced for the fact that it is only a TBI system.
1966 Clark Cortez, Industrial /6
PostPosted: Mon Feb 07, 2005 6:21 pm
You can make your own TBI system based on the GM and/or megasquirt stuffs for half that $2k, give or take. Heck, even multiport for less then $2k, machinework on a manifold for bungs and fuel rail is ~400.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 4 guests
