| intermitent vacuum leak driving me crazy https://slantsix.org/forum/viewtopic.php?t=11668 |
| Author: | argentina-slantsixer [ Mon Feb 07, 2005 10:49 pm ] |
| Post subject: | intermitent vacuum leak driving me crazy |
Here's the situation: I have a light vacuumeter on my fender. If you stomp on it, the manifold vac drops so it lites. Is connected on the same hose that power brakes. I drove my car near 300 miles and she was fine, powerful, nice. Then, acouple of days ago, after leaving her sittin for 3 hours in a cold damp place (perry como wasn't there I'll check my spark plugs to see if I can find any symptom of lean mixture... I also have been having temp issues, but not everyday, so maybe when the intermiten vacuum leak kicks in my motor likes to heat up... thanks in advance, waiting to listen to your input. |
| Author: | sandy in BC [ Tue Feb 08, 2005 8:10 am ] |
Do you have vacumn operated heater controls? |
| Author: | SlantSixDan [ Tue Feb 08, 2005 1:09 pm ] |
Yes, a bad booster diaphragm could cause a leak large enough to turn on the Fuel Pacer light, but take a close look at the brake booster vacuum check valve. It's usually right at the booster end of the large-diameter booster vacuum line, but some setups have it more towards the middle of the line. |
| Author: | argentina-slantsixer [ Wed Feb 09, 2005 2:39 am ] |
No, I don't have vac operated heater controls (lucky me, that sounds more like a pain in the a s s) Dan: you're referring to the plastic thingy that connects the large vac line to the booster? I didn't know that this li'l fellow has a checkball. I'll check that. tnx. |
| Author: | SlantSixDan [ Wed Feb 09, 2005 12:20 pm ] |
Quote: Dan: you're referring to the plastic thingy that connects the large vac line to the booster? I didn't know that this li'l fellow has a checkball. I'll check that. tnx.
Yep, that's the item.
| Author: | Mark [ Wed Feb 09, 2005 8:08 pm ] |
One other thing to check/replace is the PCV valve. They get old and dirty inside they start sticking. Just one more thing to look at. If they stick open that will sure cause a vacuum leak. |
