| Quick rearend ? https://slantsix.org/forum/viewtopic.php?t=11700 |
| Author: | crooked6 [ Thu Feb 10, 2005 10:32 am ] |
| Post subject: | Quick rearend ? |
I need to find out how to tell what size rearend I have. It is a 63valiant, I don't know how many different sizes they made or how to tell by looking. What do I do? Thank You crooked6 |
| Author: | 1969ron [ Thu Feb 10, 2005 11:14 am ] |
count number of cover bolts and post back. ron |
| Author: | crooked6 [ Thu Feb 10, 2005 1:57 pm ] |
It is a 10 bolt rearend. If it is stock, what ratio is that? |
| Author: | Rust collector [ Thu Feb 10, 2005 2:27 pm ] |
Then you have a 8 1/4" rear. Look for a little tag under one of those bolts. It has the ratio stamped in it, or something else... |
| Author: | crooked6 [ Thu Feb 10, 2005 7:58 pm ] |
I hate to say it, but if it had a tag it is long gone by now. The car is old after all. Anyway, my search continues for this ratio. I need this because I'm am trying to buy the proper speedogear to the tranny. I need rearend ratio and tire diameter, the latter being easier to figure out |
| Author: | moparfiend [ Thu Feb 24, 2005 1:05 am ] |
jack the rear end up turn the wheel 1 full turn count the number of turns the driveshaft turns. 2 and 3/4 turns 2.73:1 almost 3 turns 2.94:1 if both wheels turn the same direction you have a posi rear end . you can jack up 1 side and turn the up wheel 2 turns and count shaft turns |
| Author: | Wesola78 [ Mon Feb 28, 2005 10:11 am ] |
If you wanted to change the ratio in your diff, contact "Randy's Ring and Pinion". |
