holley 390 jetting
https://slantsix.org/forum/viewtopic.php?t=11727
Author:  Guest [ Sat Feb 12, 2005 10:04 pm ]
Post subject:  holley 390 jetting
I have a 390 cfm holley vacuum secondaries carb on a 4 bbl Offy manifold, Clifford headers, 264 duration .444" lift cam, head milled .100 and porting. Any jetting suggestions would be appreciated.
Author:  thehatedone [ Sun Feb 13, 2005 12:33 pm ]
wow,been a long time since i've been around this or anyother slant site :? Start with 64 up front 66 in the rear and work your way from there. from the experimenting i've done i put a 2" 4hole spacer on an offy intake and had really good fuel distribution also, but made it run alttle more lean. picked up .2 - .3 from the spacer alone!
-the hated one
Author:  Guest [ Sun Feb 13, 2005 5:36 pm ]
I have some metering plate instead of secondary jets. I s ther any way to get rid of this?
Author:  J Lewis [ Sun Feb 13, 2005 7:56 pm ]
You can get an adapter to replace the metering plate so that you can use standard jets. Jegs has 'em. They also have a metering block that does not use jets for the primary side; it uses adjusting screws.
