| Jerry Engle 360HP "Rollin Stoned" Hyper-Pak Dodge https://slantsix.org/forum/viewtopic.php?t=11737 |
| Author: | Ritilian=Hyper-Pak [ Sun Feb 13, 2005 8:19 pm ] |
| Post subject: | Jerry Engle 360HP "Rollin Stoned" Hyper-Pak Dodge |
With The New 150hp NOS System With #83 Jets Installed It Was Off To Test The Set Up At A Vacant Railroad Lot. One Benefit Of Being A Fireman Is Having The Firetruck Follow Me To The Railroad Strip Where I Would Either Blow The Pistons Out The Side Of The Block Or The HYper-Pak Was Gonna Scream! The First Pass Was Terrible I Hit The Button In 2nd Gear And It Was Breaking Bad, So I Backed The Timing Down 4*Degrees And Went For The 2nd Time. Coming Out Of The Hole It Was Spinning Bad Then Went To 2nd Got Sideways A Little Then It Hooked Up And I Hit The Button And It Flat Out Flew. It Was Incredible I was Blown Away, Now I See Why It Is Easy To Get Hooked On The Juice. I Don't Think I Will Be Spraying anytime Soon Again, But It Was One Hell Of A Ride.Thank God For NOS. http://www.geocities.com/gotnitro2003/R ... r-Pak.html |
| Author: | Guest [ Sun Feb 13, 2005 8:23 pm ] |
| Post subject: | Re: Jerry Engle 360HP "Rollin Stoned" Hyper-Pak Do |
Quote: With The New 150hp NOS System With #83 Jets Installed It Was Off To Test The Set Up At A Vacant Railroad Lot. One Benefit Of Being A Fireman Is Having The Firetruck Follow Me To The Railroad Strip Where I Would Either Blow The Pistons Out The Side Of The Block Or The HYper-Pak Was Gonna Scream! The First Pass Was Terrible I Hit The Button In 2nd Gear And It Was Breaking Bad, So I Backed The Timing Down 4*Degrees And Went For The 2nd Time. Coming Out Of The Hole It Was Spinning Bad Then Went To 2nd Got Sideways A Little Then It Hooked Up And I Hit The Button And It Flat Out Flew. It Was Incredible I was Blown Away, Now I See Why It Is Easy To Get Hooked On The Juice. Thanks To All The Fireman That Stood By For Me http://www.geocities.com/gotnitro2003/R ... r-Pak.html |
| Author: | slantzilla [ Mon Feb 14, 2005 8:00 am ] |
Sounds like another Playa for a Slant street car race this summer. |
