Has your slant been through the Long run?
https://slantsix.org/forum/viewtopic.php?t=11738
Page 1 of 1
Author:  spconnor [ Sun Feb 13, 2005 8:24 pm ]
Post subject:  Has your slant been through the Long run?
The odometer on my valiant read 89245. Looking at the old fluid change notes from the previous owner, the odometer has gone around twice. So theres 289,245 miles on my engine and i drive it hard, too hard sometimes. Nothing has really failed me on the engine. It had no power at first but I later found out that my head gasket; was the same 40 year old one from flint, 2 water jakets rusted through and it was pumping coolant into 2 cylinders. I unknowingly drove it 150 miles mostly uphill to reno in the middle of july on 4 cylinders. After a new head gasket,plugs, points& condenser, cap&rotor and adjusted timing, I almost cried because it was like a whole new engine. Anyways im just amazed at how much it can handle. I'd like to hear about other engine abuse and long haul stories.
Author:  Dennis Weaver [ Sun Feb 13, 2005 8:34 pm ]
There's 245,000 miles on the engine in my Duster. Admitedly, it's built and modified now, but it's the original block, rods, and standard crank, and I race it on occasion. I built the trans for the first time at 240,000, and it was still shifting fine at that time. I knew the original owner and have all the service records from day 1.
D/W
Author:  Rob Simmons [ Sun Feb 13, 2005 11:11 pm ]
In the old Slant 6 News Magazine there was a "300,000 Miler's Club" for people with original Slant 6s with that many or more miles. There were a bunch of members in the club. Some claimed over double the 300,000 if i remember right.
Just remember to adjust the valves occasionally! :oops: :roll:
No wonder there is such a following!
Author:  64 Convert [ Mon Feb 14, 2005 4:33 am ]
The old slants are amazing engines. My son bought a Swinger with a bit over 200,000 miles on it. The previous owner had put one rod bearing in about 50,000 miles earlier, but it wasn't burning oil yet.
We bought a core engine and transmission, which we built for the day the old ones died. A few years later, when he sold the car, it was pushing 300,000 and the new engine and transmission were still waiting in the garage.
Author:  MitchB [ Mon Feb 14, 2005 7:46 am ]
In NYC, slanted taxis and police cars routinely racked up over 600K. They used to say, 'just make sure it had oil in it'.
Mitch
Author:  kesteb [ Tue Feb 15, 2005 8:56 pm ]
The engine in my '65 is a OEM '78 Aspen SuperSix. About 10 years ago, when I transplanted it into my old '64, it had 110,000 miles on odometer and it was running crappy. Once the engine was in the '64, I removed all the vacuum crap and emissions stuff. The engine performance improved 100%. 10 years later the same engine is starting to smoke a little on startup, and it is down a little on power, but with about 100,000 more miles on the engine it is performing very well.
Author:  74W100/6 [ Tue Feb 15, 2005 9:11 pm ]
Post subject:  Mileage
My 74 power wagon only reads about 80,000 miles, but my father was always looking for an excuse to do a motor swap, so he ran the piss out of the six without changing the oil for about 5 years, granted for the last three years it hasnt been a daily driver, but if you ask me thats a pretty long time of weekend hauling for no oil changes...and shes still running strong!
Author:  spconnor [ Tue Feb 15, 2005 11:16 pm ]
Post subject:  compression
I did a compression test at the shop today on my 280,000+ slant and.. 1=140 2 through 6=150;all or the guts are origional factory(rings,gaskets,bearings) the only thing that failed was that head gasket that turned 430$ for a new head, it was worth it though, Dutra you remember any of that....?. Pretty impressive for what i put it through plus whatever it may have had in the past
