E-body 8.75 into 66 Cuda
https://slantsix.org/forum/viewtopic.php?t=11740
Author:  fatbaldguy [ Mon Feb 14, 2005 12:02 am ]
Post subject:  E-body 8.75 into 66 Cuda
I have an 8 3/4 axle housing available to me from an e body cuda. I've read the article that Gunpilot did on his Duster, but I was curious if there may be any additional things for me to consider on an early A-body that anyone can think of.
Author:  kesteb [ Tue Feb 15, 2005 9:46 pm ]
An E-body axle will not fit under an A-body. Expecially a '66 cuda which doesn't have large wheel openings.
Author:  Guest [ Sat Feb 19, 2005 7:51 am ]
So even flaring out the fender and using backspaced tires wouldn't do it for me?
Author:  kesteb [ Sat Feb 19, 2005 4:06 pm ]
Well, if you want to butcher the car, then sure it will work.
But I would move the springs into the frame rails and then take the axle down to a machine shop and have them narrow it up so you can have the tires inside the fenderwells. But that is just my opinion.
Author:  slantzilla [ Sun Feb 20, 2005 6:21 am ]
E-body is waaaaayyyyyyyy too wide. Those are even wider than a C-body I believe. For the money it will cost for bodywork and offset wheels you can have a place like Moser cut the housing and cut and respline the axles so it will fit an A-body. I know Moser cut and splined my axles for about $90 and they charge the same for narrowing a housing.
Author:  fatbaldguy [ Mon Feb 21, 2005 2:27 pm ]
Thanx for the info.
