Should I shave my head,, and how much ?
https://slantsix.org/forum/viewtopic.php?t=11745
Author:  MileHighDart [ Mon Feb 14, 2005 9:22 am ]
Post subject:  Should I shave my head,, and how much ?
Ok, I meant my /6-head,,, not MY actual head. lol
SO anyway, i've removed my old intake and exhaust on my 225 in order to do a SuperSix conversion.
First thing I find is that I have two broken off studs in the head. So i'm probably going to pull the head off and take it to a good machine shop to have the broken studs removed or drilled out , or whatever.
I was thinking since i'll have the head off and at the shop, why not have them shave .070 or .080 off so I can get my compression up a little.
First question I guess is: How much should I have them take off ?
Second would be: How much could I take off without requiring other mods, like shorter push rods,, etc. ?
Car is a 68 Dart, 225, 904 auto, 2:76 gears, and its a total slug right now.
It will be driven daily year round, mostly highway driving.
I'll be doing the supersix swap when I put it back together, new 2-1/4" single exhaust,, and for now, stock cam, but maybe soon i'll do a small cam as well. I'm also gasket matching the intake and exhaust to the head, and i've opened up the "outlet" on the stock exhaust manifold to 2'1/4" as well.
Thanks
Scott
Author:  rust collector [ Mon Feb 14, 2005 10:05 am ]
Im not gonna say how much you want to take off, but remember that the replacement gaskets are thicker than the stock steel one...
Author:  Slant6Ram [ Mon Feb 14, 2005 1:09 pm ]
Post subject:  Yep
It sounds like a good plan. If the machine shop isn't overly expensive, and you need work done anyways, I say go for it.
I know that .060 is very reasonable and will allow for all stock parts. My Aspen has .060 off without any issues so far. One question is are you sure that the head has never been worked before?
If you want to go more, you may have to use a better grade of gas or adjust the timing curve, but how much adjustment is difficult to say.
The racing manual says you can safely take .090 off, and I've heard stories of people taking .1 off the block and .1 off the head without clearance problems.(but with a stock cam) I don't know if I'd build one like that for a street car.
Author:  70valiant [ Mon Feb 14, 2005 3:11 pm ]
I took 0.100" off and now premium fuel is required. I haven't had any problems with push rods, that may change when I put the head on the other engine that has a bigger cam though. If you are going through the trouble of shaving the head you should port it as well.
Author:  MileHighDart [ Tue Feb 15, 2005 8:25 am ]
Thanks for the Info !
