It is currently Sun Nov 29, 2026 1:52 pm
PostPosted: Mon Feb 14, 2005 2:39 pm
Bored, rainy day, etc., hooked up a vacuum gauge as follows: disconnected the only vacuum line running to carb (from distributor) blocked the line running to the distributor, hooked vacuum gauge to new vacuum line running to base of carb. On the outside scale of the vacuum gauge, got a steady 5. On the inside scale (cmHg vaccum) the outside number corresponds to about 15. I've read some on the good readings and I think the Hg vacuum number should be much higher. What is keeping this engine running with such low vacuum figures and where do I begin to get them higher? The ending starts and runs smoothly. (Used another gauge with same results). This engine is in a 65 Valiant with none of the smog crap. I noted that while initially warming up the exhaust leaves in addition to moister, a lot of black crap, on the driveway. What keeps this monster running?
 Post subject: How Does it Run Part II
PostPosted: Mon Feb 14, 2005 3:31 pm
I found in an old Tune Up and Troubleshooting guide that a low and steady reading (which is what I have), indicates one of two things: Late ignition or valve timing; or Low Compression. I'm leaning towards the first item. What should the timing be at idle?
 Post subject: Black Crap
PostPosted: Mon Feb 14, 2005 4:05 pm
How long has it been since this little jewel was started and run? So you see black smoke coming out the exhaust while it's warming up? Sounds to me like its idling very rich. But I'm certainly no expert at these things - 58 and still trying to learn - :lol:
dave
PostPosted: Mon Feb 14, 2005 4:16 pm
Sounds like you are taking a reading from ported vacuum, instead of manifold vacuum. In that case, your vacuum reading at idle should be low or zero.
If equipped, try hooking the vacuum gauge up to the vacuum tree on the #6 intake runner (I am unsure whether or not a '65 will have a vacuum tree... :?: )
Other wise, look for a capped off vacuum port on the carb that is below the throttle plates. That should be manifold vacuum.
Hopefully someone more savvy with 60's slants will speak up. :?
-S/6
 Post subject: Running Engine Again
PostPosted: Mon Feb 14, 2005 4:42 pm
O.K. Looked over the carb and intake a bit closer. On the driver's side of the carb, there is a large tube leading out of the carb which has a hose running from it to the PCV (PVC)sp valve on the valve cover. On the passenger side of the carb, there is only one small tube leading out of about midway down the carb and that is where the vacuum line attaches from the distributor. Nothing else to hook up to, so it is correct. Looked at the intake a bit closer and saw that there was a pipe fitting in the rear most runner to the head. Where two runners (close together) go to the head someone has screwed a bolt into that place. Going back a bit, earlier I got a rebuilt carb for the engine, and because it didn't have the right linkage on it, one of the board members said to use the base plate that I already had and just remove the new one from the new carb, and screw the new one on. I know that when trying to adjust the screw in the base plate, there is no effect on the engine. Sounds like in the near future I will have to pull the new carb off, disassemble the original base plate, soak it in carb cleaner, blow it out and see if maybe some crud is stuck in there. Keep in mind though, the darn thing runs good as it is.
 Post subject: Update
PostPosted: Tue Feb 15, 2005 5:37 am
This morning (rain quit), I tweeked the carb base a bit by tightening the mounting bolts. Took another vacuum reading and it went to as high as 8 for awhile and gradually went back to zero a couple of times.
For 74360Scamp: The car isn't run much at all. I've only started it a couple of times this past winter.
For Super6: There isn't a vacuum tee on the #6 intake runner. Just a bolt and washer filling the hole where the T would be. I'm going to look through the parts bin and see if I can find a pipe threaded cap to replace that.
Question: How thick is the carb gasket on most slants? The one on my car appears to be homemade. About an 1/8th of an inch thick, and appears to be made of some kind of insulating material.
 Post subject: Again
PostPosted: Tue Feb 15, 2005 6:11 am
Forget the idea of the pipe threaded into the intake. That bolt passes through the intake into what appears to be the exhaust manifold (about 3" or more in length). Square one, here I come.
 Post subject: Low Vacuum
PostPosted: Tue Feb 15, 2005 6:40 am
Have you searched for a vacuum leak? I doubt you have one since you say she runs good as is. Why are you concerned with the low vacuum reading? Just wondering. If she runs good as is, why mess with it? Not critizing, just wondering.
dave
 Post subject: How Does It Run
PostPosted: Tue Feb 15, 2005 8:00 am
Excellent point Dave, but the term "good" is pretty general. The car starts with some difficulty and runs uneven. Sure, it will get you down the road fine, but tries to die at stoplights etc, and takes a little throttle manipulation to keep running. I don't even know where to start to locate a vacuum leak other than maybe spraying around the carb base. Always something. Besides, I like tweaking to improve economy, etc.
 Post subject: Vacuum leak
PostPosted: Tue Feb 15, 2005 8:08 am
Well, I don't understand the whole vacuum leak thing myself, but I do know that it can mess things up a lot sometimes. The black that you are getting out the exhaust would generally mean to me that the carb is running rich. Have you pulled any spark plugs to "read" them? Did you put new plugs in it? It could also just be old carbon getting heated up and "burning" off while it's idling. I guess "we" need to get the old girl idling smoothly before moving on to other things. Have you tried adjusting the idle mixture screw - oops. I think you said in another post that you tried that and it did absolutely nothing. Hmmmmm. Messed with the timing any? Sounds like you may have to pull the carb off and clean up the old base you used, and then see how she runs.
dave
PostPosted: Tue Feb 15, 2005 11:02 am
Advance timing and see what happens.
My aspen was "wierd" in the beginning, after I got it.
It was way worse than yours, but I am sure your timing is not at 20-25 degrees AFTER tdc...
It ran smooth enough, but really lacked power, and did wierd things sometimes.
Make sure your timing marks are where they should be too.
