| installing yoke on 71/4 pinion https://slantsix.org/forum/viewtopic.php?t=11784 |
| Author: | guest [ Thu Feb 17, 2005 10:06 pm ] |
| Post subject: | installing yoke on 71/4 pinion |
Hey guys , i am getting ready to change the rear axle pinion seal on the 71/4. I read how to measure the preload,remove the tight nut, pull the yoke with bolt type puller. My question is how to get the yoke back on? Hammer part way then use nut on threaded part to screw in yoke? Is yoke easy to slide back in on the splines? thanks any advice really helpful |
| Author: | slantzilla [ Sun Feb 20, 2005 6:26 am ] |
The yoke should slide back on far enough that you can seat it when you torque the nut. |
| Author: | guest [ Sun Feb 20, 2005 9:28 pm ] |
| Post subject: | thanks for your advice |
thanks for your advice, i always read about various topics here and i learn alot and feel more confident to fix things on my 75 duster. |
