| 63 Engine mounts - same as 66? https://slantsix.org/forum/viewtopic.php?t=11789 |
| Author: | sixsignet [ Fri Feb 18, 2005 9:17 am ] |
| Post subject: | 63 Engine mounts - same as 66? |
Looking for engine mounts for a 63 225. NAPA has them for 66. Can I use them w/o modification? |
| Author: | Rust collector [ Fri Feb 18, 2005 9:40 am ] |
I think they changed in 67? But I have been wrong before... |
| Author: | 64 Convert [ Fri Feb 18, 2005 12:18 pm ] |
The part numbers are different, though I strongly suspect they can be interchanged. According to the parts manual, the '66 convertible has different mounts than the sedan, but I don't know what the difference might be. The last time I checked NAPA, they didn't carry any of the old A-body mounts, so if you found some, they must be old stock in a local warehouse. |
| Author: | Charrlie_S [ Fri Feb 18, 2005 5:15 pm ] |
If I remember correctly, the NAPA catalog is wrong. It lists the same mount from 66-69. The mounts changed between 66 and 67. |
| Author: | kukla64valiant [ Tue Feb 22, 2005 10:08 am ] |
| Post subject: | Motor mounts |
I got mounts for my 64 valiant from action auto in Seattle. I think they where made by Anchor? It tool them a bit. Napa in Seattle did not have them. I also believe that the 63 is the same. I also paid less than 45 bucks total. You can also try www.jcauto.com, 425-672-8324. Great mopar folks and they also have them on hand. Steve |
