It is currently Mon Nov 30, 2026 1:43 pm
PostPosted: Fri Feb 18, 2005 9:17 am
Looking for engine mounts for a 63 225.
NAPA has them for 66.
Can I use them w/o modification?
PostPosted: Fri Feb 18, 2005 9:40 am
I think they changed in 67?
But I have been wrong before...
PostPosted: Fri Feb 18, 2005 12:18 pm
Contributor
The part numbers are different, though I strongly suspect they can be interchanged. According to the parts manual, the '66 convertible has different mounts than the sedan, but I don't know what the difference might be.
The last time I checked NAPA, they didn't carry any of the old A-body mounts, so if you found some, they must be old stock in a local warehouse.
PostPosted: Fri Feb 18, 2005 5:15 pm
If I remember correctly, the NAPA catalog is wrong. It lists the same mount from 66-69. The mounts changed between 66 and 67.
 Post subject: Motor mounts
PostPosted: Tue Feb 22, 2005 10:08 am
I got mounts for my 64 valiant from action auto in Seattle. I think they where made by Anchor? It tool them a bit. Napa in Seattle did not have them. I also believe that the 63 is the same. I also paid less than 45 bucks total. You can also try www.jcauto.com, 425-672-8324. Great mopar folks and they also have them on hand.
Steve
Users browsing this forum: Ahrefs [Bot], Dart270, DuckDuckGo [Bot] and 3 guests
