| Suggestions for pump gas build https://slantsix.org/forum/viewtopic.php?t=11813 |
| Author: | DustedIn05 [ Sun Feb 20, 2005 7:32 am ] |
| Post subject: | Suggestions for pump gas build |
Right now i have the stock holley single. I bought a super six setup, and will be buying a 2nd engine next month which is where it will go. Looking for alot of info. Not for racing, but something better than stock. Block boring.? .020. .040 Piston Selection? i know they sell overbore.. What brand is the best? Manifold porting.? Cam suggestions? Looking to spend under $1000 Anything will help. Thanks |
| Author: | Doctor Dodge [ Sun Feb 20, 2005 8:59 am ] |
It is going to be hard to get real involved with this rebuild and keep it under $1000.00 You may want to call around for a remanufacatured short block assembly, I got one a while back from Kregans for just under $600.00 If you can do a lot of work yourself, the disassembe some engines to see if you can find one that just needs a basic "rings and bearings" overhaul, then put you money into a cam and head work and your set. DD |
| Author: | DustedIn05 [ Sun Feb 20, 2005 9:15 am ] |
The Engine i plan on buying is from a guy by me.. its supposed to have 35k on it. Mine has 189,000, hehe, so i dont think it's a good candidate. This is my first rebuild, but I plan on doing the work myself.. with the help of a couple of motorhead friends of mine. so you recommend to have head work done, have a bigger cam installed, and call it a day. If the engine truly has 35k on it, then everything theoretically should be fine.. i guess i'll find out when i pick it up. |
