It is currently Mon Nov 30, 2026 10:34 am
PostPosted: Sun Feb 20, 2005 11:23 am
I went to get a set of spark plugs for my /6, but i don't remember the year of the engine that i got the head off of. it's the newer style without sparkplug tubes. What do i need to ask for when ordering a set of plugs? Also, at the rear end of the intake/exhaust flange, there is a small hole that looks like something bolts onto. What is this?
Nick
PostPosted: Sun Feb 20, 2005 11:35 am
Asking for spark plugs for a '76 Dart will get you the correct type (e.g. Autolite 25 or 26 with resistor, or 15 or 16 without resistor); the "no spark plug tubes" head started in '75.
The hole at the rear of the head is for exhaust port air injection. You need to plug/block this off or you'll have an exhaust leak there.
PostPosted: Sun Feb 20, 2005 12:24 pm
Unless yours is just a blind hole, like the one in my RBL style head. :shock:
D/W
If it ain't broke, fix it!
