3800rpm @ 75mph
https://slantsix.org/forum/viewtopic.php?t=11903
Author:  spconnor [ Wed Feb 23, 2005 11:22 pm ]
Post subject:  3800rpm @ 75mph
Cruising on the highway at 75-80mph, my engine is reaching 4000rpm. I hear of people cruising at 2-2.5k; What must be done to reduce engine RPM at high speed. I went from 13(185x60)'' to 14'' sbp cop wheels and that seemed to help. 225 with a 727 ; 3 on tree; 150#s in all cylinders, reaching 300k miles; smooth~
Author:  70valiant [ Thu Feb 24, 2005 5:34 am ]
you need to change your rearend gears. It sound like you are running 3.91's. I'm running 3.23's and 235/60R14's, I turn 3000rpm at 75 mph.
when I was running 2.76's and 225/75R14's I would turn 2400rpm at 75mph.
Author:  DusterIdiot [ Thu Feb 24, 2005 7:53 am ]
Post subject:  Speedo gear...
Not to ask the question, but when you changed rims, did you change tire size and did you change the speedo gear in the tranny to compensate for tires/etc...?
Someone on here should have a conversion chart/ reference to help out.
good luck,
:wink:
Author:  spconnor [ Thu Feb 24, 2005 11:50 am ]
No, I did not change the speedometer gear, infact after i removed the insturment panel to replace bulbs, my speedometer doesnt even work. I've tried to clean and grease it but nope. Is there any info on fixing those or installing a new one? Anyways I dont know the exact gear ratio but its a 69' 7 1/4 with what i eyeballed at around 2.75
Author:  spconnor [ Mon Feb 28, 2005 10:36 pm ]
I got my speedometer to work correctly now (that was harder than it should've been) And that 3800rpm speed is at 80-85..maybe thats why my gas mileage is so bad. 25'' dia rear tires. 2.76 gears. 727 3spd tree.
Author:  sandy in BC [ Tue Mar 01, 2005 8:24 am ]
65 Valaint 3.23 gears 235/60/14 tires, 2350RPM at 83 mph,,,,, .70 overdrive.
