Attn:Dart270
https://slantsix.org/forum/viewtopic.php?t=11945
Page 1 of 1
Author:  DART68 [ Fri Feb 25, 2005 8:38 pm ]
Post subject:  Attn:Dart270
How are you doing? Have you checked this site out? www.transmissioncenter.net They have vacuum and oil pressure switches that will eliminate the need for toggle switches to activate the lock-up and overdrive features of the 518 transmissions. I plan to make contact to find out if these also cover the A-500 transmissions. Found this link in Car Craft's What's Your Problem section of the April 2005 edition.
Hope you find this interesting.
Dart68
Author:  gmader [ Sat Feb 26, 2005 6:18 am ]
Post subject:  Wow, now that is an annoying website.
I haven't seen a more difficult to use webiste in a long time.
This is what happens when web designers start using meth.
Here is the link to their A500 page
http://www.transmissioncenter.net/dodge.htm
Author:  Dart270 [ Sun Feb 27, 2005 2:09 pm ]
Looks like a pretty good and simple system, with cheap parts. I have thought of building an electronic circuit to do this, but it's low on the list. What they propose should work fine for everyday usage.
