Correct Fluid level without dipstick
https://slantsix.org/forum/viewtopic.php?t=11992
Page 1 of 1
Author:  DusterMunster [ Mon Feb 28, 2005 4:58 pm ]
Post subject:  Correct Fluid level without dipstick
I had my transmission repaired a couple of months ago, it is a 904. But some jerk at the shop misplaced my dipstick and put in a Ford's. It has been impossible for me to find the right one for some time, no even at Ebay. How can I know the right level using in the meantime the Ford dipstick?. This is making me add a lot of fluid every now and then, and of course I am finding spills all over the garage... I know it may be because I overfilled the slump, but I panic thinking my transmission would crash if I do not add more to replace the lost fluid, which I think was lost because it was in excess... it is a viscious (and expensive) circle :(
Author:  Dennis Weaver [ Mon Feb 28, 2005 5:13 pm ]
...somebody send this man a 904 dipstick, stat! (did you try a Chrysler/Dodge dealer, by the way?)
D/W
Author:  DusterMunster [ Mon Feb 28, 2005 5:16 pm ]
Thank for the reply Dennis, yes I tried, but no one seems to care about dipsticks for 904's, I tried yunkyards, lost a couple of bids on Ebay because I did not check my PC on time... I think the solution in the meantime is to find someone with a 904 and borrow the stick for a quick check...
By the way, love your signature... it is wise
Author:  mighty mouse 63 [ Mon Feb 28, 2005 5:29 pm ]
Post subject:  Opps sorry!
By do I feel Stupid :oops: I tossed one several months ago, I have a second one that escaped my bout of temporary insanity, its your when I find it.
Author:  Guest [ Mon Feb 28, 2005 5:34 pm ]
Thanks a lot... it would be great if you find it. I am about to file for bankruptcy for all the $$$ spent in Mercon III
Author:  DusterMunster [ Mon Feb 28, 2005 5:36 pm ]
Oops, it was my post but I was not logged in... sorry :oops:
Author:  Dennis Weaver [ Mon Feb 28, 2005 6:08 pm ]
Post subject:  Re: Opps sorry!
...its your(s) when I find it.
This is what I love about this board! There's more than money to be made in old cars. Making friends, exchanging tricks and helping others rank highly, too!
Spread the /6 love! :wink: :D
D/W
Author:  Seis Inclinado [ Sun Mar 06, 2005 5:49 pm ]
904 tranny dipstick measurements. Tranny in my 79 Plymouth Valiant..
Top to bottom:
Length from upper stop to tip 46.2 cms., or 18-3/16 inches
From upper stop to the full mark 41.6 cms., or 16-3/8 inches
From upper stop to the add 1 pint mark 43.2 cms., or 17 inches
From bottom up:
From the tip to the add 1 pint mark 3.0 cms., or 1-3/16 inches
From the add 1 pint mark to the full mark 1.6 (1.58 ) cms., or 5/8 inches.
Other:
Width of blade 7 mm., or 9/32 inches
Lenghth of handle 10 cms., or 3-15/16 inches.
Maybe you can "remark" your Ford dipstick to these readings...while you find the correct unit.
Buena suerte carnal
Author:  Seis Inclinado [ Sun Mar 06, 2005 6:17 pm ]
Re my post above:
While going to the garage to return the dipstick to the Valiant it occurred to me to compare it to the dipstick in the wagon 360 / 727......
Guess what? They are identical!...
Hmm, the wagon has been mine since day one and I'm positive it has the right dipstick, but I don't know about the Valiant, for I bought it used and this is the stick it came with.
So I don't know. Maybe some one else can clear this up.
Author:  DusterMunster [ Mon Mar 07, 2005 8:01 am ]
Gracias Rafa... I will check if the 904 dipstick is similar to the 727's. If so, I will measure mine and make the check.
Saludos!!!
Eduardo
