| What do think of this build? https://slantsix.org/forum/viewtopic.php?t=11997 |
| Author: | Mike_64_Valiant [ Mon Feb 28, 2005 8:55 pm ] |
| Post subject: | What do think of this build? |
The car is being built as a sleeper. For starters. The block Stock bottom end. Head port&polish-oversized valves-3 angle valve grind Cam Compcams 264S offey 4bbl intake man. Holley 390 my question is I would like to expand to Nitrous in the future. The stock bottom end should hold up right? Should I use the ARP connecting rod bolts or is that over kill. And will the Holley 390 be enough for the cam. Thanks Michael |
| Author: | Doctor Dodge [ Mon Feb 28, 2005 10:12 pm ] |
You have a good basic build-up listed, I would mill the head at least .060 to help compression. The stock rod bolt will be OK but the ARP replacements are a lot stronger. Adding the stronger bolts is a good thing, especially if you need to resize the con rods anyway. DD |
