It is currently Mon May 18, 2026 12:31 pm
PostPosted: Sun Feb 27, 2005 10:03 pm
I have one of each. Does the Offy intake have a lot more lowend than the Clifford intake on a stock slant? I would be using a 2bbl carb, nothing outrageous here. I've had this Clifford intake for a few years now, and I have an exhaust manifold with the carb heat deal cut down, and welded over.
I might try it anyway just to see.
'78 Volare 225
'67 Charger 318
PostPosted: Mon Feb 28, 2005 12:29 pm
It's not a big difference, but the Offy will have a little more down low, which is where a stock Slant works well.
PostPosted: Mon Feb 28, 2005 12:37 pm
You need to use the clifford, and send the offy to me... :wink:
PostPosted: Tue Mar 01, 2005 6:04 am
Okay, I'll probably just use the Offy.
I might try the Clifford though, since I have it.
Thanks for the responses! :)
'78 Volare 225
'67 Charger 318
