It is currently Sat May 09, 2026 1:48 pm
 Post subject: Pertronix coil
PostPosted: Wed Mar 02, 2005 3:46 pm
I am looking to add a pertronix coil to their ignition that is already in the car. What is the difference between the 1.5ohm and the 3.0ohm? Is there any real advantage to using the three ohm? I don't really understand what they mean and any help would be appreciated. I have the Ignitor, not the II, and will be using accel 8mm wires. Thanks.
"that's a nice car....are you gonna fix it up some day?"
PostPosted: Wed Mar 02, 2005 4:40 pm
I believe the 3ohm is for use with non-resistor ignition systems.
D/W
If it ain't broke, fix it!
