| 1977 Volare' donor car https://slantsix.org/forum/viewtopic.php?t=12010 |
| Author: | spconnor [ Tue Mar 01, 2005 11:33 am ] |
| Post subject: | 1977 Volare' donor car |
I have a 69 valiant100 with the sbp 9'' in the front. There is a fairly unstripped 77 volare with disc brakes at the wreking yard. Would the UCA and spindles swap right in? Or do i have to find ONLY a 73-6 a-body with discs |
| Author: | Dart270 [ Tue Mar 01, 2005 1:07 pm ] |
Spindles and brake parts will work, UCAs will not. You can get UCAs from ANY 73-up Abody (drum or disc). Lou |
| Author: | spconnor [ Wed Mar 02, 2005 10:38 pm ] |
The volare' isn't a a-body? I'm confused as to what the body types are. |
| Author: | Pierre [ Wed Mar 02, 2005 10:58 pm ] |
No, Aspens and Volares are considerd F bodies. I've seen a more thorough chart somewhere but this is the one I've just found: http://www.moparts.org/moparts/tech/pages/bodycode.html |
| Author: | Dennis Weaver [ Wed Mar 02, 2005 11:06 pm ] |
"A-body" was Valiant, '63-up Dart and derivatives, '64-'69 Barracuda, and all Dusters. Not sure if the '60 -'62 Lancers and Valiants are referred to as "A-bodies", anyone? Aspen and Volare are "F-bodies", similar in size and layout to previous "A-bodies", but not the same. D/W EDIT: Sorry about the echo, Pierre and I must've been replying at about the same time |
| Author: | VDART [ Thu Mar 03, 2005 4:45 am ] |
| Post subject: | brake swap |
Try this link -for further disc brake info______ http://www.bigblockdart.com/tech/spindles.shtml |
| Author: | moparguest622 [ Fri Mar 11, 2005 8:21 am ] |
the lower control arms are different on the Volare. the Aspen/Volare models are F bodys and use a transverse torsion bar front suspension system as opposed to the A bodys, which use a longitudinal torsion bar setup. two entirely different animals here. |
| Author: | gummardane [ Fri Mar 11, 2005 8:25 am ] |
the 60-62 valiants and lancers are widely considered as A bodies, even though Chrysler didn't officially designate A, B, & C bodies until 1965. |
