| Squeak https://slantsix.org/forum/viewtopic.php?t=12022 |
| Author: | jl737 [ Tue Mar 01, 2005 8:38 pm ] |
| Post subject: | Squeak |
My '74 Dart has developed a very annoying squeak. |
| Author: | sandy in BC [ Tue Mar 01, 2005 8:42 pm ] |
I would check your lower balljoints. |
| Author: | jl737 [ Tue Mar 01, 2005 8:58 pm ] |
I thought that too but I greased them and it didn't help. I have noticed that if I drive through a puddle it will stop for a few days or so, but it always comes back. It is only on the driver's side. |
| Author: | kesteb [ Thu Mar 03, 2005 4:10 pm ] |
Check the battery tray. My '65 squeaks on the drivers side and it is the battery tray. |
| Author: | Jeb [ Sun Mar 13, 2005 3:24 pm ] |
Could be a shock also. |
| Author: | steponmebbbboom [ Sun Mar 13, 2005 4:00 pm ] |
Why not have a friend jounce the suspension while you poke your head around and listen? You should find the source within short order. A mechanic's stethoscope or even a screwdriver with its handle in your ear should help you narrow it down further. |
| Author: | Craig [ Sun Mar 13, 2005 5:09 pm ] |
| Post subject: | Re: Squeak |
Quote: My '74 Dart has developed a very annoying squeak.
My 1976 Valiant has the same annoying squeak too. I think its the aftermarkt strut rod rubber bushings I put in it. When going up and down over bumps/uneven surface or just sitting still and turning the steering wheel the lower control arm goes up and down and the strut rod is pivoting in the rubber bushing it causes squeek. I think this is the rubber strut rod bushing sliding on the metal. I will investigate in spring when car comes out of storage.
| Author: | Doctor Dodge [ Mon Mar 14, 2005 5:00 am ] |
Check those big bolts that attach the K-Frame to the frame rails, I have see those work loose and cause noise. Do the two person "bonce test" and is you can't pin-point the noise "by ear", grab a can of WD-40 and start spraying everything that moves. You will know it when you spray the problem spot. DD |
