Source of steel shim head gasket
https://slantsix.org/forum/viewtopic.php?t=12070
Author:  rrither [ Thu Mar 03, 2005 8:33 pm ]
Post subject:  Source of steel shim head gasket
I have the block and head at the machine shop, and am preparing for assembly. I find my FLAPS has only the (felpro) composition style head gasket, I find in searching this site, that the .030 I am having shaved off the head will be taken up by the composition gasket.
Is there a source for the stock style steel shim gasket? I have looked locally, and on e-bay with no luck. Not too late to up the amount taken off the head if need be. Any thoughts ? Other options ?
Thanks.
Author:  Charrlie_S [ Thu Mar 03, 2005 9:08 pm ]
There are some of those gaskets still around. I have a few on the shelf, but prefer not to sell any at this time. If it were me, since you are haveing the head milled, anyway, I would just take off an additional amount and use the composition gasket.
Author:  rrither [ Fri Mar 04, 2005 7:43 pm ]
Thanks. That is what I will do.
Author:  Guest [ Fri Mar 04, 2005 9:02 pm ]
what is the thickness of the steel head gasket anyway?thanks,,speedfreak.
Author:  Charrlie_S [ Sat Mar 05, 2005 2:56 am ]
Aprox .022 compressed.
Author:  Guest [ Sat Mar 05, 2005 7:27 pm ]
thanks,,charrie_s
