It is currently Sat Jun 20, 2026 3:27 pm
 Post subject: 225 Dipstick and tube?
PostPosted: Tue Mar 08, 2005 12:03 pm
I have an after market dipstick on my 64 225 and there is no dipstick tube. Does anyone know what year 225's I can raid at my local pick part yard for a stock dipstick and tube?
Thanks.
PostPosted: Wed Mar 09, 2005 11:08 pm
60-66 would use the short tube and dipstick. The later years used longer ones. Any SL6 dipstick/ tube will swap in, I kinda like the longer ones.
PostPosted: Wed Mar 09, 2005 11:28 pm
For what its worth, the original engine in my '72 Satellite had a short dip stick. I went with the longer when the tip of the short one broke off (always wondered what that ticking sound was) :shock: .
PostPosted: Thu Mar 10, 2005 12:18 am
I drained my oil pan....fill the filter up, fill the crankcase with oil, let it sit for a few hours....and installed a BB chrome dipstick in mine. You have to file away the shaft a little and then seal it with some ultra copper. I put the dipstick in, marked the spot where the oil was on the dipstick, then hit it with a grinder and left a mark, about 1" down i grinded it again, this is the "add oil" level. Works like a champ. Looks sweet too
Users browsing this forum: Ahrefs [Bot] and 1 guest
