It is currently Sun Nov 15, 2026 4:38 pm
PostPosted: Fri Mar 03, 2006 4:54 pm
I'm about to do a trans.filter and fluid change on the wagon and the Ebooger cheapie tuneup. I've done this several times in the past to other cars/trucks of mine but it's been some time ago. With the past two years of hurricane reshuffling of my files I can't find the copy of that Mopar Action article. I know that the acumulator spring is removed , The 1-2 line pressure @the valve body is turned up and the fluid is changed to type F (I do not do the fluid change). I keep thinking there is one more step but my memory fails (a lot) ..... Does anyone have said copy or remember the steps??
1977 Volare wagon auto Air,1977Volare wagon 4spd OD, 1985 short bed D100,4spd.OD
PostPosted: Sun Mar 05, 2006 5:10 am
bruce-
i have the august 2000 issue right here and the three items you mentioned are pretty much it. it's a good idea to pull the accumumator piston out and insert a steel rod behind it to keep it from moving. the only other thing i'd do is adjust the bands while you're there.
i could scan the article and email it to you if you like.
-james
