| Spark plug replacement https://slantsix.org/forum/viewtopic.php?t=12181 |
Page 1 of 2 |
| Author: | DusterMunster [ Fri Mar 11, 2005 1:32 pm ] |
| Post subject: | Spark plug replacement |
My good friend SlantSixDan recommended to replace my current plugs with Champion RN13LYC because they are getting wet very often and making the engine to idle erratically. This to correct the problem and achieve better performance before I replace the rings and perform a major repair. Unfortunately I could not find those plugs, but got Autolite 985. The guys at Pep Boys told me that it is an equivalent part and that will work just as well... I already bought them, but need to know if it is correct. If not, I am selling a set cheap!!! Thanks, Ed |
| Author: | SlantSixDan [ Fri Mar 11, 2005 2:56 pm ] |
985 should have the same extra-extra long electrodes as RN13LYC. I would've suggested 985s but I didn't realize you can get Autolites. The only real difference is that the Autolites have a 5/8" hex instead of 13/16". Do you have a digital camera to show us the electrodes on the 985s? |
| Author: | DusterMunster [ Fri Mar 11, 2005 3:03 pm ] |
Dan, I got one, but not with me right now, I will post the pics tomorrow... so I think I did ok by getting the 985s... Cool Thanks, Ed |
| Author: | DusterMunster [ Fri Mar 11, 2005 4:10 pm ] |
One more question... what should be the gap in the electrodes of the 985s??? Ed |
| Author: | SlantSixDan [ Fri Mar 11, 2005 4:24 pm ] |
Ordinary gap. I run 0.035" with points, 0.040" with Chrysler electronic, 0.045" with GM HEI conversion. |
| Author: | DusterMunster [ Tue Mar 15, 2005 11:42 am ] |
Here are the pics of the extra-long electrodes of the Autolite 985... ![]() ![]()
| Author: | SlantSixDan [ Tue Mar 15, 2005 11:43 am ] |
Yep! Those are the right ones! |
| Author: | DusterMunster [ Tue Mar 15, 2005 11:52 am ] |
Thanks Dan, will install them right away... I am still working on your parts, will send you a PM soon... couldn't go on Saturday, but will this week. Ed |
| Author: | SlantSixDan [ Tue Mar 15, 2005 11:58 am ] |
No problem -- thanks! |
| Author: | steponmebbbboom [ Tue Mar 15, 2005 4:04 pm ] |
Hey... those are the same plugs I run in my Slant. I tried getting 925s with just the extended electrode but they said the p/n is superceded... havent noticed a difference anyway... |
| Author: | DusterMunster [ Tue Mar 15, 2005 4:57 pm ] |
I just intalled the plugs... started the engine and it ran erratically... Thanks a lot. Ed |
| Author: | Johnny Z [ Tue Mar 15, 2005 7:04 pm ] |
Thats odd.Autolite 56 or 66 are the plugs that are coming up for slants.Why are you going with a 985? |
| Author: | steponmebbbboom [ Tue Mar 15, 2005 7:19 pm ] |
For the double extended nose. |
| Author: | SlantSixDan [ Tue Mar 15, 2005 7:58 pm ] |
Quote: Thats odd.Autolite 56 or 66 are the plugs that are coming up for slants.Why are you going with a 985?
The double-extended electrodes move the spark point out towards the center of the combustion chamber and away from the metal edges. The plugs were originally designed for tough-to-light engines (desmogged AMC 232/258, Chrysler TBI 318s in '81-'83 Imperials), 'cause the mixture is much less variable in the middle of the chamber than at the edges, and these long-electrode plugs give more consistent light-off of the cylinder under borderline-combustibility conditions. A similar electrode set is used in some of the recent-model Chrysler 3.5 litre engines.I use 'em in my '89 Ram TBI 318, my 2.2/2.5 cars, my slant-6s... |
| Author: | Craig [ Tue Mar 15, 2005 8:40 pm ] |
So there must be adequate clearance from the plug tip to the valves and piston? |
| Page 1 of 2 | All times are UTC-07:00 |
