It is currently Thu Jun 18, 2026 9:22 am
PostPosted: Sat Mar 19, 2005 1:12 pm
http://viewmorepics.myspace.com/index.c ... 0319130537
wat am i working with here? i just got it..
PostPosted: Sat Mar 19, 2005 1:59 pm
Looks pretty clean, and looks as if someone's already swapped on a Super Six 2bbl setup, so you're ahead of the game already. Is this a handshift or an automatic car?
(I also see that it's got power steering.)
PostPosted: Sat Mar 19, 2005 2:05 pm
dan so wats up with the double barrel setup is that good...? and they redid the manifold too?
PostPosted: Sat Mar 19, 2005 2:06 pm
its a push button automatic lol
PostPosted: Sat Mar 19, 2005 2:11 pm
Yep, 2bbl is good, and yep, they put on the matching 2bbl intake.
PostPosted: Sat Mar 19, 2005 2:58 pm
do u know the size of that engine dan and how much horsepower im getting just by looking at it. estimate?
PostPosted: Sat Mar 19, 2005 3:30 pm
Could be either a 170, a 198 or a 225 cubic inch displacement engine. If it's the original engine it's either a 170 or a 225. To know for sure, we'll have to know the numbers stamped on the top surface of the engine block, below the frontmost spark plug, inboard of the cast-iron alternator support bracket. You may have to use some solvent, a rag and a screwdriver to wipe the number pad clean.
Do not use "u" when you mean "you". Type out the word.
PostPosted: Sat Mar 19, 2005 3:38 pm
i have to check that out fosho... thx man
PostPosted: Sat Mar 19, 2005 6:14 pm
omgwtflolbbq shift one one one. What's the rest of the car look like?
