It is currently Sun Jun 21, 2026 12:00 pm
PostPosted: Sun Mar 20, 2005 7:31 pm
On the backside of the plenum (facing the drivers fender) theres a plug there. Any idea what that was meant for? It would be a perfect location for a manifold air temp sensor for my ms setup.
Its 3/4" npt, right?
PostPosted: Sun Mar 20, 2005 8:55 pm
3/4" NPT is HUGE. Are you sure?
NPT dimensions refer to the inside diameter of the pipe fitting. If the hole is 3/4" in diameter I would guess that it is 3/8"? but you should take the plug with you to Brafasco or something and have them identify it to be sure.
PostPosted: Sun Mar 20, 2005 9:11 pm
Whoopsy, brain fart, yeah 3/8" npt, I was thinking 3/4" because thats what the size of the hex nut on the sensor I was thinking of using.
Users browsing this forum: Bing [Bot], Rob Simmons and 2 guests
