| gonna buy a flowmaster 40 series for my 1964 dodge dart gt https://slantsix.org/forum/viewtopic.php?t=12317 |
| Author: | shamhC [ Sun Mar 20, 2005 8:44 pm ] |
| Post subject: | gonna buy a flowmaster 40 series for my 1964 dodge dart gt |
what size would be good for my car that has a 1 2 barrel carb, and a super 6? gonna buy it real soon so let me know ? 2inch 2 1/4 2 1/2 |
| Author: | steponmebbbboom [ Sun Mar 20, 2005 8:51 pm ] |
Your car doesn't have a 1 barrel 2 carbs, it has ONE two-barrel carb. Seriously, get it running right before you start hotrodding it. |
| Author: | shamhC [ Sun Mar 20, 2005 9:03 pm ] |
my car is running what are you talking about stephonn... i need to know what size pipe i should get? |
| Author: | SlantSixDan [ Sun Mar 20, 2005 9:19 pm ] |
*plonk* |
| Author: | 63Dart [ Mon Mar 21, 2005 2:39 pm ] |
Id does not need to be very thick, since your car is probably not built up that much. Do you mean that you have two one bbls (a la offy) ??? 2 inch or 2 1/4 should be fine. I would not spend too much money on your exhaust, though. Unless your engine is fairly built up, or you have a restrictive exhaust system to begin with, you will probably not attain much of a performance gain by going to a louder muffler. Your best performance bets are going to be in the areas of making sure your timing is advanced enough, that your mechanical advance has got a good curve, that your cars(s) is/are tuned and jetted correctly, that your tires are inflated properly, that your brakes aren't dragging, that your front end is aligned. Also, check your plugs to make sure they are good, and check your intake to make sure you have no intake leaks. |
| Author: | 73dart_swinger [ Mon Mar 21, 2005 3:36 pm ] |
i had 2 1/4 on my car with the stock manifold and a 40 series delta flow. it should help your performance some. it helped mine going from the stock size to 2 1/4. |
| Author: | shamhC [ Mon Mar 21, 2005 5:51 pm ] |
ill see how it feels when i get it in the mail and put it on.. |
| Author: | Pyper6970 [ Mon Mar 21, 2005 7:56 pm ] |
Buy some earplugs while your at it, the cool factor with the noise lasts only a few weeks, then it gets annoying, I run dual cliffords with 2 1/4" to the delta 50 series and then 2" over the rr end and to the tail. Its still noisy as all hell but its way quieter than the 40's. I have delta 70s (deisel mufflers) and it greatly silenced the exhaust up.
| Author: | argentina-slantsixer [ Wed Mar 23, 2005 8:49 pm ] |
Quote: *plonk*
Dan, you're the man. I can't stop laughing.
