| Ball and Trunnion/Pot Joint Boot Replacement https://slantsix.org/forum/viewtopic.php?t=12333 |
Page 1 of 3 |
| Author: | Guest [ Tue Mar 22, 2005 2:32 pm ] |
| Post subject: | Ball and Trunnion/Pot Joint Boot Replacement |
Well while working on my transmission leak, I noticed a stripe of grease inside the transmission tunnel. It turns out the boot for the Ball and Trunnion/Pot Joint on the drive shaft has cracked. I was hoping not to have to deal with this until I had the drive shaft shortened for my rear end upgrade. It looks as though I need to either replace the boot or change the shaft over to the spicer type u joint. I read that you can use a CV joint from a Dodge Caravan. I think Doc posted this. Is there a specific year that works best? Is there any sort of technique to doing this other than what is in the service manual? Does this last? Thanks, John |
| Author: | killin5 [ Tue Mar 22, 2005 2:34 pm ] |
Sorry, that was me. I could have sworn that I logged in. John |
| Author: | Charrlie_S [ Tue Mar 22, 2005 2:41 pm ] |
This is from the EVBC mail list. Posted with permission from the sender. I found all of the fresh reproduction rubber driveline boots any of us could need. In my research, and before I had to pay to have them made I discovered: Roberts Motor Parts 800-231-3180 Boots cost 22.50 each. There are two sizes, (Which caused me to get mad a Frank Mitchell for selling me a small one.) They look exactly the same, only one is smaller in length for smaller engines and one is larger for full size Mopar products. This is very good news for all, and for the person who asked about larger vehicles. I'm told by Gary Roberts he can look up the size you need and stocks both. I told Roberts he needs to advertise better because guys like me have wasted money on more expensive 40 year old boots of questionable quality. |
| Author: | SlantSixDan [ Tue Mar 22, 2005 2:45 pm ] |
| Post subject: | Boot & rebuild kit availability |
I had the cross-and-roller conversion done on the driveshaft that's in my '62. Pretty much any good driveshaft shop can do it; it involves a spline that bolts to the trans output flange, a slipyoke and a cross-and-roller U-joint. The use of a late-model FWD CV joint is an interesting idea! I've never heard of this, so I hope we get some details on that. Note that if the B&T front U-joint in your driveshaft is still good, you can just replace the boot. Andy Bernbaum has the boot/clamp kit, Q102, $22.50. He also has the complete front U-joint rebuild kit (which includes the boot and clamp kit), Q112, $75. Website is http://www.oldmoparts.com . |
| Author: | Dennis Weaver [ Tue Mar 22, 2005 3:31 pm ] |
I alwez hear Californians and others refering to "driveshaft shops" like there's one on every corner! D/W |
| Author: | steponmebbbboom [ Tue Mar 22, 2005 3:40 pm ] |
Have you tried looking in a commercial trade directory, like Fraser's or thomas register? thomasnet.com check under services>repair and maintenance. |
| Author: | SlantSixDan [ Tue Mar 22, 2005 3:47 pm ] |
Quote: I alwez hear Californians and others refering to "driveshaft shops" like there's one on every corner!
They are in every area I've ever lived in, small towns and big cities alike.D/W Pick up your yellow pages! |
| Author: | Charrlie_S [ Tue Mar 22, 2005 4:16 pm ] |
We have a couple in my area. The one I use treats me very well. Made me a conversion driveshaft, for $125, parts and labor. Will do for OP for $175. http://www.earlycuda.org/tech/ujoint.htm |
| Author: | SlantSixDan [ Tue Mar 22, 2005 4:21 pm ] |
Yep, that is exactly the conversion I've got on my '62. |
| Author: | Dennis Weaver [ Tue Mar 22, 2005 6:05 pm ] |
Quote: Quote: I alwez hear Californians and others refering to "driveshaft shops" like there's one on every corner!
They are in every area I've ever lived in, small towns and big cities alike.D/W Pick up your yellow pages! D/W |
| Author: | SlantSixDan [ Tue Mar 22, 2005 8:27 pm ] |
AMERICAN DRIVE SHAFT SVC 765 S COBB DR SE MARIETTA, GA (770) 499-9804 CUSTOM DRIVE SHAFT & HYDRAULIC 2150 MORELAND AVE SE # B ATLANTA, GA (404) 622-2800 DRIVE SHAFT SVC 1395 COBB PKWY N MARIETTA, GA (770) 427-4898 |
| Author: | Dennis Weaver [ Tue Mar 22, 2005 9:37 pm ] |
Quote: AMERICAN DRIVE SHAFT SVC
Fantastic! I don't know whether you're trying to prove me stupid or help me out, but either way, I appreciate it! 765 S COBB DR SE MARIETTA, GA (770) 499-9804 CUSTOM DRIVE SHAFT & HYDRAULIC 2150 MORELAND AVE SE # B ATLANTA, GA (404) 622-2800 DRIVE SHAFT SVC 1395 COBB PKWY N MARIETTA, GA (770) 427-4898 D/W |
| Author: | Pierre [ Tue Mar 22, 2005 9:57 pm ] |
www.yellowpages.com, mmhmmmm Other then the ones Dan posted I found this one as well ROME DRIVE SHAFT SERVICE 24 RIVERSIDE INDUSTRIAL PARK NE, ROME, GA 30161 Phone: (706) 295-9292 |
| Author: | Dennis Weaver [ Tue Mar 22, 2005 10:27 pm ] |
...far from one on every corner and in every small town, but good enough for me! D/W |
| Author: | Guest [ Wed Mar 23, 2005 11:19 am ] |
[quote="Dennis Weaver] Fantastic! I don't know whether you're trying to prove me stupid or help me out[/quote] Always assume the latter! It was an interesting search. www.yellowpages.com turned up zero results, but www.qwestdex.com turned up those three! |
| Page 1 of 3 | All times are UTC-07:00 |
