| Self Adjusting Valves? https://slantsix.org/forum/viewtopic.php?t=12358 |
| Author: | ole_blue [ Thu Mar 24, 2005 8:51 pm ] |
| Post subject: | Self Adjusting Valves? |
I'm just curious, did the slant ever come out with self adjusting valves or did advance auto pull a fast one on me? All I've ever seen had the rocker arm with the adjusting screw, that is until I got this engine. It's a 81 engine by the way. |
| Author: | Eric W [ Thu Mar 24, 2005 10:41 pm ] |
An '81 engine uses hydraulic lifters....no adjustment for the valves. I believe they started using them in '80 or so. |
| Author: | SlantSixDan [ Fri Mar 25, 2005 10:25 am ] |
There was a small test run of hydraulic-equipped slants in '78, and then no more until the '81 model year, when all slants got hydraulic lifters. |
| Author: | Craig [ Fri Mar 25, 2005 4:41 pm ] |
Quote: There was a small test run of hydraulic-equipped slants in '78, .......
Yea, all 20,000 of them. Anyone ever find one? According to the service bulletion they were all decked out Volaré/Aspen models with Air Conditioning. |
| Author: | ole_blue [ Sat Mar 26, 2005 6:52 am ] |
well the rocker arm assembly on my slant has no adjusting screws, so I guess it has the hydralic lifters you speak of. It's been a good motor so far and it has never smoked. The reason I asked was I was wondering if this would have anything to do with my run on problem. Thanks for the info. ole_blue |
