It is currently Fri Jan 02, 2026 10:15 pm
 Post subject: Self Adjusting Valves?
PostPosted: Thu Mar 24, 2005 8:51 pm
I'm just curious, did the slant ever come out with self adjusting valves or did advance auto pull a fast one on me? All I've ever seen had the rocker arm with the adjusting screw, that is until I got this engine. It's a 81 engine by the way.
PostPosted: Thu Mar 24, 2005 10:41 pm
An '81 engine uses hydraulic lifters....no adjustment for the valves. I believe they started using them in '80 or so.
PostPosted: Fri Mar 25, 2005 10:25 am
There was a small test run of hydraulic-equipped slants in '78, and then no more until the '81 model year, when all slants got hydraulic lifters.
PostPosted: Fri Mar 25, 2005 4:41 pm
There was a small test run of hydraulic-equipped slants in '78, .......
Yea, all 20,000 of them. Anyone ever find one? According to the service bulletion they were all decked out Volaré/Aspen models with Air Conditioning.
PostPosted: Sat Mar 26, 2005 6:52 am
well the rocker arm assembly on my slant has no adjusting screws, so I guess it has the hydralic lifters you speak of. It's been a good motor so far and it has never smoked. The reason I asked was I was wondering if this would have anything to do with my run on problem. Thanks for the info. ole_blue
Users browsing this forum: Google [Bot] and 25 guests
