| Mystery Engine Year https://slantsix.org/forum/viewtopic.php?t=12362 |
| Author: | Jimmy T. [ Fri Mar 25, 2005 8:39 am ] |
| Post subject: | Mystery Engine Year |
I have a 1964 Plymouth Belvedere with a .225 Slant 6. The engine is not the original but a rebuild instead. The previous owner could not tell me the year of the engine. I have heard that different .225 years take certain carburetors. Currently I have a single barrel Holley in there and I have a suspicion that it is not quite the right one because neither I nor any other mechanics can get her adjusted just right. Does anyone know how I can determine the year of my engine? |
| Author: | slantvaliant [ Fri Mar 25, 2005 9:10 am ] |
These may help you identify what you have: http://www.slantsix.org/articles/parts-matrix/jpg.htm http://www.slantsix.org/articles/dutra- ... blocks.htm The year of the engine itself - the long block - won't make a lot of difference in being able to tune it. There are a few different cams, several intake manifold/carb combinations, and then there are the emissions controls and such to deal with on some engines, but on a '64 you should be able to keep it simple. |
| Author: | slantvaliant [ Fri Mar 25, 2005 9:15 am ] |
By the way, I have a '64 Valiant, with what appears to be the original Carter BBS one-barrel. Simple carb. I don't know anything about the Holleys. What, specifically, is the problem with tuning your car? |
| Author: | Jeb [ Fri Mar 25, 2005 6:25 pm ] |
With sucha heavy car, I would put in a 71-77 cam (more torque). I've heard that the Carter BBS is the best one barrel for the slant.If it is a 70's motor it probably has a crappy Holley 1945 smog carb on it. |
| Author: | Dennis Weaver [ Fri Mar 25, 2005 6:34 pm ] |
Quote: With sucha heavy car, I would put in a 71-77 cam (more torque). I've heard that the Carter BBS is the best one barrel for the slant.If it is a 70's motor it probably has a crappy Holley 1945 smog carb on it.
You're not gonna believe this jeb, but for now, I'm gonna have to side with the cheesy old 1920 Holley as the best 1-bbl pick. Two attempts with two different BBS's (one an NOS unit) have met with abject failure, and I puuled every trick known to man (or is that Dan So my experience has been (from best to worst) BBD (2-barrel) works like a charm every time. Holley 1920 (one barrel) BBS (one barrel) Holley 1945 (one barrel, throw this one in the trash) D/W |
| Author: | SlantSixDan [ Fri Mar 25, 2005 7:43 pm ] |
That cam is actually '71-'80, and is the stock cam that's sold for all '60-'80 slant-6s through all engine parts suppliers. The MP 244 is better (same duration, greater lift).Quote: I've heard that the Carter BBS is the best one barrel for the slant.
That's the one I've had the most consistently good results with.
| Author: | SlantSixDan [ Fri Mar 25, 2005 7:50 pm ] |
Quote: BBS just want's to be way lean during the warm-up cycle.
Strange indeed -- I've never had one that couldn't be made to behave correctly during warmup. Then again, I've also never messed with the '70-'72 "open stove" choke setup, either. I did find that source for electronic choke conversion kits and sent them an inquiry this afternoon, and will keep you up to date.I suspect if you have a '60-'69 or '73-up exhaust manifold with matching choke thermostat, you'd have no trouble at all. The '70-'72 setup was a stopgap to meet warmup emissions before they figured out how to do electric-assist chokes in '73. |
| Author: | Dennis Weaver [ Fri Mar 25, 2005 8:08 pm ] |
Quote: Quote: BBS just want's to be way lean during the warm-up cycle.
Strange indeed -- I've never had one that couldn't be made to behave correctly during warmup. Then again, I've also never messed with the '70-'72 "open stove" choke setup, either. I did find that source for electronic choke conversion kits and sent them an inquiry this afternoon, and will keep you up to date.I suspect if you have a '60-'69 or '73-up exhaust manifold with matching choke thermostat, you'd have no trouble at all. The '70-'72 setup was a stopgap to meet warmup emissions before they figured out how to do electric-assist chokes in '73. The thing is, when the Holley is a bit lean on warmup (say on an unexpectedly cold day during the months when I keep the heat riser wired shut - yes, I know you don't approve D/W |
