It is currently Sun Oct 27, 2024 12:15 am
 Post subject: Engine Year???
PostPosted: Wed Mar 30, 2005 7:41 am
I'm not sure the year of my .225 Slant 6 that sits in my '64 Belvedere. I know it's not the orignial. Is there a way to find out???
PostPosted: Wed Mar 30, 2005 10:58 am
One more time:
This is what D-Idiot wrote:
0225 R 1024 E
0=model year or plant number (1970 or 1980 if model year)
225=Cubic inch displacement
R= engine usage code:
R=Passenger car engine
1024=shift it was built on
E=parts ID code:
A=oversize cylinder bore
E= Cast Crank shaft
X=o/s valves
These numbers aren't entirely conclusive either in some cases, my 1974 block just says 3W 225 4 06 on the pad
(1973, 225, 406 shift code...)
Can't wait til you open it up and ring the crank with a wrench to see if it rings or has a dull sound to it....
Otherwise, a 1980 cast crank passenger car mill...
Lasse
Signet -66 225
Holley 600 Offy-5270 Dutra Dual,regrind. cam 272 0,420 110, head shaved 0.100 slight.ported
MSD6A
A904
7 1/4 3.23
PostPosted: Wed Mar 30, 2005 11:26 am
0225 R 1024 E
Letter codes were still being used for engine date in 1970 (specifically, 1970 was "F"). So, this is probably a 1980 engine.
Users browsing this forum: Ahrefs [Bot] and 5 guests
