Slant Six Forum https://slantsix.org/forum/ |
Engine Year??? https://slantsix.org/forum/viewtopic.php?t=12430 |
Author: | Jimmy T. [ Wed Mar 30, 2005 7:41 am ] |
Post subject: | Engine Year??? |
I'm not sure the year of my .225 Slant 6 that sits in my '64 Belvedere. I know it's not the orignial. Is there a way to find out??? |
Author: | skraecken [ Wed Mar 30, 2005 10:58 am ] |
Post subject: | |
One more time: This is what D-Idiot wrote: 0225 R 1024 E 0=model year or plant number (1970 or 1980 if model year) 225=Cubic inch displacement R= engine usage code: R=Passenger car engine 1024=shift it was built on E=parts ID code: A=oversize cylinder bore E= Cast Crank shaft X=o/s valves These numbers aren't entirely conclusive either in some cases, my 1974 block just says 3W 225 4 06 on the pad (1973, 225, 406 shift code...) Can't wait til you open it up and ring the crank with a wrench to see if it rings or has a dull sound to it.... Otherwise, a 1980 cast crank passenger car mill... -D.Idiot |
Author: | SlantSixDan [ Wed Mar 30, 2005 11:26 am ] |
Post subject: | |
Quote: 0225 R 1024 E 0=model year or plant number (1970 or 1980 if model year) |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
