It is currently Sun Jan 05, 2025 8:41 pm
PostPosted: Thu Mar 31, 2005 6:42 am
Last night, after "tweaking" the choke adjustment a bit, it once again, started right up by depressing the peddle once and holding it half way down. I tried it again this morning - about 32* outside. Depressed peddle to set choke, held half way down, started on second try, then settled into a nice idle. Was able to kick it down a notch or two off of the fast idle cam with no problems.
Now, I just need to get rid of that stumble off idle.
dave
PostPosted: Thu Mar 31, 2005 9:03 am
Run max initial timing advance. Increase pump shot. What's your carb type?
D/W
P. S. - ideally, if everything is jam-up, you should be able to depress and release the pedal one time and start up dead cold and idle without touching the gas again.
If it ain't broke, fix it!
PostPosted: Thu Mar 31, 2005 9:15 am
DW - I think it's a 1945 carb. I'm pretty sure it's whatever came on the car originaly in 1974. Yes, I thought about changing the linkage for more of a pump shot, and advancing the timing some. It's awfully close now.
dave
Users browsing this forum: Google [Bot], Semrush [Bot] and 3 guests
