Slant Six Forum https://slantsix.org/forum/ |
FURTHER UPDATE !! Is my fuel draining out of carb? https://slantsix.org/forum/viewtopic.php?t=12452 |
Author: | 74360scamp [ Thu Mar 31, 2005 6:42 am ] |
Post subject: | FURTHER UPDATE !! Is my fuel draining out of carb? |
Last night, after "tweaking" the choke adjustment a bit, it once again, started right up by depressing the peddle once and holding it half way down. I tried it again this morning - about 32* outside. Depressed peddle to set choke, held half way down, started on second try, then settled into a nice idle. Was able to kick it down a notch or two off of the fast idle cam with no problems. Now, I just need to get rid of that stumble off idle. dave |
Author: | Dennis Weaver [ Thu Mar 31, 2005 9:03 am ] |
Post subject: | |
Run max initial timing advance. Increase pump shot. What's your carb type? D/W P. S. - ideally, if everything is jam-up, you should be able to depress and release the pedal one time and start up dead cold and idle without touching the gas again. |
Author: | 74360scamp [ Thu Mar 31, 2005 9:15 am ] |
Post subject: | |
DW - I think it's a 1945 carb. I'm pretty sure it's whatever came on the car originaly in 1974. Yes, I thought about changing the linkage for more of a pump shot, and advancing the timing some. It's awfully close now. dave |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
