Slant Six Forum https://slantsix.org/forum/ |
Whats a good idling hot oil pressure? https://slantsix.org/forum/viewtopic.php?t=12455 |
Author: | markjs [ Thu Mar 31, 2005 10:09 am ] |
Post subject: | Whats a good idling hot oil pressure? |
I just got my oil gauge rigged and I don't know what numbers are dangerous. I specifically need to know the average and lowest tolerable pressures at full warm on a low idle. Thanks in adavance |
Author: | ole_blue [ Thu Mar 31, 2005 10:13 am ] |
Post subject: | |
My 225 slant reads 50 steady. |
Author: | Super6 [ Thu Mar 31, 2005 10:51 am ] |
Post subject: | |
IMO, lowest tolerable at hot idle: 5 psi General rule of thumb, you want 10 psi oil pressure for every 1000 rpm; 10 psi for 1000 rpm, 20 psi for 2000 rpm, etc. My slant runs about 35 psi oil pressure at hot idle, 52 psi everywhere off-idle--that is on a fresh rebuild with approx 1500 miles though. -S/6 |
Author: | Eric W [ Thu Mar 31, 2005 10:53 am ] |
Post subject: | |
Mine is 50psi at idle, cold. Goes down to 25psi warmed up. Is 50psi at all driving speeds warmed up. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
