| Brake Tee thingy https://slantsix.org/forum/viewtopic.php?t=12480 |
| Author: | relic-lover [ Sat Apr 02, 2005 5:01 pm ] |
| Post subject: | Brake Tee thingy |
I am trying to determine if what I have in my 61 Valiant rear brake lines is the stock "brake tee" or some type of proportion valve added by a PO. This part has the two steel lines to each wheel and the Brake flex hose coming to it. It is mounted on the 7.25 rear ends axle tube - The reason I think it may be a proportion valve is the top seems to be a round knob - may just be a cap or vent since it does not seem to turn. Can anyone tell me if what I have described would be a stock brake tee used on 61 ? |
| Author: | VDART [ Sat Apr 02, 2005 5:10 pm ] |
| Post subject: | axle tube vent |
That's the axle tube vent, it also holds the junction block for the brake lines as you noted, it was the same on the 60-62 valiants that I have messed with the past 2 years, you have the rare v-8 conversion correct? How is that running? Later- Lawrence |
| Author: | SlantSixDan [ Sat Apr 02, 2005 5:10 pm ] |
Sounds like you're seeing the stock brake tee and the round rear axle vent. |
| Author: | relic-lover [ Sat Apr 02, 2005 5:40 pm ] |
| Post subject: | Thanks ! |
No there is no V-8 It is a Slanted Car ! Had a 225 which I pulled - And there is a 170 hyper pak in the works for under its hood - But the project this weekend is a master cylinder and hard lines for the KH discs that were put on it over the last year. Thanks again ! |
| Author: | VDART [ Sat Apr 02, 2005 5:52 pm ] |
| Post subject: | v-8 |
Sorry, thought you were someone else that cruises in a road toad with a 360 sandwiched between the fenders. Anyhow I'm down to my 62 sedan & plan to make it more than just my work vehicle (still slant powered) |
