| oil in cil 4 https://slantsix.org/forum/viewtopic.php?t=12490 |
| Author: | Matadem [ Sun Apr 03, 2005 5:36 pm ] |
| Post subject: | oil in cil 4 |
all cil are good except number 4 my car is running like crap now ...and I got to fix it as soon as possible... engine block has been resleeved , new rings..og pistons could this be a broken ring? bad valve seal what else could it be? anyone? |
| Author: | Dart270 [ Sun Apr 03, 2005 7:12 pm ] |
bad valve guide, rings didn't break in properly... Any bad noises? Did you do a compression check? How do you know there's oil in cyl 4? Are the valves adjusted properly? Lou |
| Author: | Pierre [ Sun Apr 03, 2005 7:16 pm ] |
Cracked head? Was it magnafluxed when rebuilt? |
| Author: | Matadem [ Sun Apr 03, 2005 7:35 pm ] |
I will do a compr. test tommorow If its rings .... I maybe could get some at napa or I could order some os pist and rings from Usa and rebore block but it will take about a month for parts to get here if it guides I do have new ones but I didn't want to use them yet since I got os valves to go with them to build a good head how do I know... the sparkplug is covered with oil I've put a adapter for temporary fix....but I need to fix this |
| Author: | Avenger2040 [ Sun Apr 03, 2005 7:48 pm ] |
| Post subject: | For me... |
this sounds like a bad valve seal, you hear something like a "flap, flap" sound when engine is running?, that happened with a friend´s Mustang. |
