vaccum leak?
https://slantsix.org/forum/viewtopic.php?t=12504
Author:  1sick66cuda [ Mon Apr 04, 2005 2:17 pm ]
Post subject:  vaccum leak?
Timing is correct....but still backfiring through the carb under load
Author:  Doctor Dodge [ Mon Apr 04, 2005 10:59 pm ]
Have you checked the valve lash? A tight valve can cause that. (tight lash or a sticking guide or a flat cam lobe)
Also a worn distributor shaft can cause the timing to "move around", is the mark steady as you rev up the engine?
