brake lights Question
https://slantsix.org/forum/viewtopic.php?t=12564
Author:  VDART [ Sat Apr 09, 2005 8:08 pm ]
Post subject:  brake lights Question
checking my brake light situation & lo* behold 1 side works 1 side does not-- 62 valiant, any how put in new bulbs as it is e-z-- get this now the other side works --but not both together!! all other lights are fine-- tail, turn signal-- but if I wiggle one taillight why the brakes are appled they only both stay lit for a secind then 1 over-rides & that side works -- any suggestions? both terminals are not corroded, I'll trace the wiring Sunday for bad connections/ground. Just thought this was odd!!!!!!
Author:  Avenger2040 [ Sat Apr 09, 2005 8:57 pm ]
Post subject:  Check bulbs...
Check failing side bulb ground, if is like my 71 Valiant, ground is inserted with light bulb, if is the same, just dont insert all the way of ground with light bulb in the socket, just the tip.
Author:  Avenger2040 [ Sat Apr 09, 2005 8:58 pm ]
